what size drill bit?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=6439
Author:  ecklesweb [ Sun Apr 30, 2006 3:01 pm ]
What size drill bit do I want to use for Schaller scallop-style tuners with
press-fit bushings? 21/64 is a little snug - I'd have to find a way to
hammer the bushings down. 22/64 is a little loose - I'd have to put a
drop of CA or some other adhesive or maybe wrap a piece of masking
tape around the shaft of the bushing.
I'm leaning towards the 21/64, I'm just worried about cosmetically
damaging the bushing when I try to hammer it home.
Author:  Rod True [ Sun Apr 30, 2006 3:06 pm ]
What if you drilled the 21/64 hole and just wraped some sand paper around a 5/16 bit and drilled/sanded slowly to open it up?
Just a thought.
Author:  Cocephus [ Sun Apr 30, 2006 3:13 pm ]
Tap, tap, tap with a neoprene (plastic) hammer? Depending on how tight they really are...
Author:  Alain Desforges [ Sun Apr 30, 2006 4:06 pm ]
10 mm?
Author:  Kim [ Sun Apr 30, 2006 9:34 pm ]
I think they may well be 10mm, but test drill some scrap and try it out. When you are fitting them, use a hardwood drift to set them home and you will not mar the finish.
Cheers Kim
Author:  Bruce Dickey [ Sun Apr 30, 2006 9:53 pm ]
A tapered ream is the proper tool. Shouldn't be too expensive. But then I got mine at a salvage equipment place for fifty cents.
Author:  1bordeaux [ Sun Apr 30, 2006 11:10 pm ]
Jay,
If you have a drill press, Chuck a carraige bolt or something similar and use it to press in the bushings. I use a large round head carraige bolt which gives me more of a sight line so I don't over press.
Author:  Phil Marino [ Sun Apr 30, 2006 11:38 pm ]
Try either a size "Q" or size "R" drill. Here are the sizes in decimal ( rounded to the nearest 0.001 inch):
21/64 - .328
Q - .332
R - .339
22/64 - .344
Both of these drills are "lettered drills" and are between the two sizes you tried. These are machinist size drills. You can get a complete set of numbered and lettered drills (115 drills, altogether) from Harbor Freight for about $30. These range from 0.040 inch diameter to 1/2 inch.
I bought a set recently, and I wish I had years ago. It's great to have the EXACT size drill you need. (or, usually within a couple of thousands of an inch).
Right now Harbor Freight has a titanium nitride coated set on sale for $40., but I have a "plain" HSS set from them, and they work great, even drilling steel.
Also, if you have a good hardware store nearby, you may be able to buy just the individual drill you need (Q or R) but it's real convenient to have the whole set.
Phil
Author:  old man [ Mon May 01, 2006 12:30 am ]
My Schallers need a 10mm hole.
Author:  Colin S [ Mon May 01, 2006 12:54 am ]
Yep 10mm.
Author:  charliewood [ Mon May 01, 2006 3:22 am ]
I have a good trick for turning your regular hammer into a non-marring hammer, that will prevent cosmetic damage you speak of.
Take a rubber foot - the ones that go under aluminum round frame fixtures, tables, old man walker's, crap like that
and just slide it over your hammer end - voila, I find that it works so good that I use the thing on more than off these days.
Its not a drill bit solution but its a hammer that sucker in solution.
Charliewood
